If I get a big bore kit,,,do I need anything else
Old May 5, 2004 | 11:29 PM
quadracer18's Avatar
Default If I get a big bore kit,,,do I need anything else
I'm not a genious on big bore kits...I know they bore out your engine.....but I plan on boring my scrammy out to a 600 later on this year.....will I have to do anything else if I get this bore kit...like,,,will I need a higher mm carb? higher piston? cam? rejet? anything of that sort..or will it be once I get the big bore in it then it will be ready to fly??
quadracer
Old May 6, 2004 | 03:21 AM
Sidewinder500's Avatar
You might want to look into a +1 swingarm to help in keeping the front end down a lil.
Old May 6, 2004 | 08:32 PM
dragracer789's Avatar
you should get it ported at the same time, and also get a bigger carb and pipe so it will flow more gas/air! The piston/rings should come with the kit if its a good one. I would also get a higher lift or duration cam for it.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
