pads for wolverine
Old May 6, 2004 | 07:02 PM
eja's Avatar
eja
Default pads for wolverine
I have had my wolverine for about a year now and it looks like I'm going to have to replace my break pads soon. Need to know what some good after market brands would be, or would I be better getting factory? I want good pads. I trail ride. some mud and water. Thanks for the input on this thread.
Old May 6, 2004 | 07:24 PM
wolverine68's Avatar
Personally, I haven't found anything that is as good bang for the buck as the stockers.
Old May 9, 2004 | 05:58 PM
wolverine01247's Avatar
You haven't changed pads in a year, amazing. I ride in western Massachusetts and if I use rear pads like you normally do, they only last about 4 rides. We have lots of mud and water. With this machine I've learned to ride using just a little front brake. The front and rear pads have different part numbers but are interchangeable. The rear ones have a tab on side backing plate. You can grind tabs off for the front if you need to.
Old May 11, 2004 | 02:40 PM
trahsub's Avatar
4 rides? Holy smokes. That is like 300 miles on a set of pads? How do you wear them out so fast 01247?
Old May 11, 2004 | 02:55 PM
The mud just grinds away at the rear pads. I've learned to ride using just the front brakes, they last a lot longer ( about two sets a season ).
Old May 11, 2004 | 06:58 PM
eja's Avatar
eja
I mainly use the front breaks also. Use engine breaking mosly down hills. Do you guys use factory breaks for replacement?
Old May 11, 2004 | 10:43 PM
shastadog's Avatar
I like yammy brakes. None of these brakes for Wolvys are worth a ****. It does seem the Yammy brakes last a little longer.
suzuki230
Jul 8, 2016 10:03 AM
toonces
Aug 21, 2015 01:19 PM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
holmbergm97
May 27, 2015 07:23 AM
