650 belt question
Old May 7, 2004 | 04:42 AM
arcticcop's Avatar
Default 650 belt question
ON my 04 650 when I go to take off easy it seems the motor revvs a smidge then the bike moves. It does not seem crisp. When it is off and in gear you can push it very easily with little drag. I removed the cover and the belt seems awful loose to me. I do not know how tight it should be but if you push the top of the belt down it will move over an inch. The belt light is not on. Does this mean it is time to go see the dealer or is this just the joys of a belt?? Any info would be great!!
Old May 7, 2004 | 10:21 AM
DaveB's Avatar
The Kawi spec is 27 to 22 mm deflection using a flat bar placed across the belt and measuring with 13 lbs of downforce on the belt. Mine was like yours.....I suspect most are on the loose side. I've been told that for good belt life you want to be on the tight side of the spec. I changed the spring in my secondary (driven) clutch and at that time I removed one of the shims in the clutch. This makes the secondary narrrower and tightens the belt. Good instructions and tips: HERE
Old May 7, 2004 | 07:40 PM
meathead1's Avatar
read your fix and how to make the clutch tool from the link on your reply. great info thanks [img]i/expressions/face-icon-small-happy.gif[/img]
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
Logan Collins
Sep 5, 2015 08:03 PM
