Low to high range
I was cruisin the trails today and found some fallen rcoks i thought no problem, so i switched it from high to low no problem going over the rocks no problem, then put it back to high that is where it got stuck pulling the shift rod harder and harder it would not budge. i turned off the cat and it went to high easy. It still continues to do the same. thing plus when going from low to high,i put it into gear and it sounded like it was trying to put it into gear(Clink,clink,clink) then it would engage. I need advice.
Thank
Marcus
Thank
Marcus
