Whats This Part on my 300EX?
Old Jul 28, 2000 | 12:01 PM
Ryan300EX's Avatar
I own a 97 300EX. The last two months I have had battery problems. The problem is my battery won't hold the charge. I replaced the battery yesterday and checked to see if there was a drain on the system. I had .7V drainning the battery. I traced it to a single part on the ATV. The part is located on the clutch side, mounted next to the air filter box, and looks like a large heat sink with 4 wires coming out. Can someone identify the part, provide information on its purpose and tell me how much money to replace? Thanks for you help and sorry for my stupidity.
97 300 EX & 00 Recon
Old Jul 28, 2000 | 04:56 PM
jeepin's Avatar
I am not sure of what the name of what your talking about.I do know what U are talking about.It is a little box with heat fins on it.Hope this helps to have someone else identify it.
Old Jul 28, 2000 | 05:09 PM
Skunky's Avatar
Humm It has to be an amplifier or it is suppose to drain energy. Humm I will call honda..hehe
It is the voltage Regulator.. They could not tell me if it was suppose to drain voltage but i will check mine when i get home...
Old Jul 30, 2000 | 02:28 AM
trick250rX's Avatar
I am having the exact same problem with my ex, it will be ok if I ride i everyday but if it sits longer than a day it will be dead ( it is a new moto power battery)
Old Jul 30, 2000 | 11:07 AM
Mike300EX-99's Avatar
To keep your battery from draining unhook your neg wire off the battery when not in use. You probably have a bad rectifier/regulator unit which is leaking as it sits, or the battery has an internal short.
Old Jul 30, 2000 | 06:52 PM
veedell's Avatar
I've heard of this problem being caused by water. A friend of mine had one go bad on his '00 EX, so on the new one he siliconed around all the connectors.
nosaj
96 350XX
#94 MHSC
#401 SOIL
Old Jul 31, 2000 | 01:51 AM
azrob's Avatar
Its your rectifier, it converts the AC charging power from your engine to DC. Its also the only component that remains connected even when your ignition switch is off. If its only a
rectifier then replacement should be less than $100.00, if it contains the regulator or CDI the price could run up to around $300.00.
Old Aug 4, 2000 | 08:33 AM
Exer_95's Avatar
The prices quoted above are for new parts !! If you need a cdi or a that other part call East Coast ATV in Pa. I bought a CDI for $50. It s out of a 99'.
Good Luck !!!
Asaran
Oct 8, 2015 11:14 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
