Speed differences with 12 tooth on aWarrior?????
Old Jul 28, 2000 | 12:43 PM
razormazer's Avatar
If i change my stock 13 tooth sprocket to a 12 tooth, how much top end will i loose and how much " out of the hole " punch will i get?
Old Jul 28, 2000 | 02:35 PM
hot_shoe_cv's Avatar
I don't know of anyone usin a 12 T c/s sprocket on a Warrior unless they use it for a tractor. I'd hazard a guess & say you'd give away 5 to 10 mph on top and corresponding amounts in mid range. When I switched to 20" tires on my Warrior I saw a big drop in speed & big increase in rpms. A 14" c/s cog returned it to more or less normal. I now run a 15" and still have plenty of low end; enough to break the Bandits loose up to 3rd gear.
12 teeth is the low minimum recommended to minimize strain on the chain & c/s itself. Even so, the sharp angle the chain must achieve to travel around the small sprocket has to be considerable stress on the links.
Old Jul 28, 2000 | 07:14 PM
Yamaha350War's Avatar
I have a 12 tooth on my warrior. I do alot of mountain riding so I got a set of Pure Sport REaltor tires for the rear. To turn those with some power is why I went lower on the sprocket. It does lower the gearing signifigantly. I think I will kick up my rear to a 42 to even it out a little more. The plus is right now I can really drag race. And at high altitude 5500+ I can actually use 6th gear now. I also have aluminum proflo adapter with a K&N airfilter and a Procircuit T-4 pipe. I can go through any snow and mud that a 4x4 can. I'm looking at getting a torque stuffer or a new cam next.
mywifesquad
8
Sep 21, 2015 08:20 AM
Steeldon
Sep 9, 2015 09:38 AM
black_thunder
Sep 6, 2015 04:41 PM
Brandon400
Sep 5, 2015 08:44 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
