Bolt pattern for the 04 DS650 Rims Front and rear
Can anyone tell me if the bolt pattern for the DS650 is the same with Kawaski Mojave or even a yamaha warrior with either one frt or rears? Tire size doesn't matter to me just rim bolt pattern, thx New DS Rider
KFX 400 and some others use a 4 on 144 front rim. You can usually get them to work if you have to. The only problem is the center opening is often not big enough to go over the DS hub and will have to be turned down. For sure not worth the effort, just order DS rims, but in a pinch it works.
Justin
Justin
