Blaster tie rods
Old May 9, 2004 | 06:22 PM
blasterrcr9587's Avatar
Default Blaster tie rods
Does anyone know where i can get a tie rod for pretty cheap?? i broke mine when i hit a tree on accident.. any help would be appreciated.
Old May 9, 2004 | 11:32 PM
i mean tie rod ends.. sorry
Old May 9, 2004 | 11:33 PM
Shav0's Avatar
Tie rod ends? Like the ball joints?
On the blasters the ball joints are attached to the a-arm itself. If that is the case, and you broke a ball joint, then you are looking at getting a new set of a-arms.
Old May 9, 2004 | 11:34 PM
Jaydawg's Avatar
nevermind
Old May 10, 2004 | 12:35 PM
no, the tie rod end is the piece that connects the tie rod to the hub.. ill try and get a picture of it tonight. it has happened before but the place that i got it at closed down.
shavo, i see that you have the T.O.R.S. eliminator kit on your blaster, does yours idle because i have that on mine but it doesnt idle. if it does how did you get it to idle?? thanks
Old May 10, 2004 | 12:38 PM
mojavekid13's Avatar
Blasters suck bad that way
Almost every other bike, is the same as my old mojave, you can replace it sepertly, witch is much much easyer and cheaper
Old May 10, 2004 | 01:48 PM
Shav0's Avatar
blasterrcr9587,
Mine idles fine. Do you have a idle kit installed in your carb when you removed the tors system?
exmotocrosser
Sep 13, 2019 06:12 AM
Ahtatu
Sep 28, 2015 12:14 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
nastyblaster100
Sep 13, 2015 01:19 PM
