jetting help
Old May 9, 2004 | 07:28 PM
UltimateAussie's Avatar
Default jetting help
i just put a UNI air filter on my quad and now it keeps cutting out and dying. and then it wont start without holding down the throttle. could it be jetting and should i go smaller or larger
thanks in advance
Old May 9, 2004 | 10:48 PM
ThrashAndCrash's Avatar
If it ran fine before the filter change than all you need to do is increase your fuel. USUALLY this does not happen. If a filter change made that big of a difference that your old one was completley plugged or you were on the utmost limit of your jet anyway. before you go buy a jet change your clip position a little first. Move the clip DOWN toward the pointed end! This will raise your needle and give you more fuel.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
