raptor carb problem help plz
Old May 10, 2004 | 08:47 PM
duke9074's Avatar
Default raptor carb problem help plz
hey my raptor wont idle and when i revv it up high it will clear up but will miss once in a while. Then after i release the gas it wont come down to idle right away. Any ideas and how do i fix it?
Old May 10, 2004 | 09:10 PM
HMFIC's Avatar
If it just started all of the sudden it is unlikley that the carbs are out of adjustment. One of the slides might be hanging or they might be out of sinc. If there is a hose between the carbs, maybe it has fallen off. The most likely thing is an air leak. I am willing to bet that you have one between the carb and head. When you have the engine running take some carb cleaner and spray around the intake tracks. If the engine stumles or dies you have found your leak. I am not real familier with the raptor but I figure I might could give you a couple of ideas.
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
need4aquad
Feb 4, 2001 03:26 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
