How Big is too Big???
Old Jul 29, 2000 | 01:51 PM
00HondaEX's Avatar
I was wanting to know with a high compression piston could I bore my 2000 300EX with running into reliability problems?
Old Jul 29, 2000 | 02:46 PM
426ex's Avatar
11:1, bore it and run it!!!!
Old Jul 31, 2000 | 12:01 AM
puddding's Avatar
starter motor?......
Old Jul 31, 2000 | 10:01 AM
94DGblaster's Avatar
you can make it a 330, or a 405!
GO BIG!!! and if the starter burns up..put a kick on it from a 250X(I have NO idea if that works..)
Old Jul 31, 2000 | 01:30 PM
00HondaEX's Avatar
I was woundering if that was possible to put the kick starter on it and find a way to make the headlight I never use run off the RPM's like a Blaster and get rid of the battery. Is the 405 bore and stroke or just bore.
Old Jul 31, 2000 | 10:51 PM
fmfblaster1's Avatar
Only cool quads run the light off the rpms.
Old Jul 31, 2000 | 11:23 PM
hakmazter's Avatar
305 is as large as you can go without doing lower engine mods (i.e. stroking or modifying) From 282, it works pretty good. 305 kit WB E series with header, Uni filter, the cam White Bros recommends for that piston (10.5 to 1)and rejet and a few holes in the lid and you will almost keep up with a stock 400ex.
