STARTING
Old Jul 30, 2000 | 02:44 AM
caseys's Avatar
I HAVE A 96 300EX IT WILL NOT START WITH THE CLUCH IN AND IN A GEAR. IT WILL ONLY START IN NEUTRAL ANY WAY TO FIX THIS?
1996 300EX SKIDS ALL AROUND,STILL LOOKING FOR A PIPE,DG GRAB BAR
1998 DR 350 STOCK
SOON TO BE 2000 400EX
Old Jul 30, 2000 | 10:48 AM
exlax250x's Avatar
the sensor in the clutch lever might be bad
c400ex1234's Avatar
when i replaced my stock clutch perch, with a cr250 style one, i noticed a black button inside of the clutch perch, this button, when compressed, will not allow the quad to start assuming that the clutch is not being pulled in, becuase when the clutch is not pulled in, the lever rests on the switch. IF i were you, i'd remove the handlebar plastic, and cleane the whole clutch perch really good, look for the black box that is hidden inside of the perch, it should be held in by a metal plate, remove the metal plate and clean the black box. If this little box is broken, then you may have to hot wire it, which is also very simple. You'll figure it out (hopefully), later
Old Jul 30, 2000 | 12:53 PM
exlax250x's Avatar
like i said
Old Jul 30, 2000 | 12:59 PM
caseys's Avatar
thank you all for your info
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
