carb trouble??
Old May 16, 2004 | 11:44 PM
rudyraptor's Avatar
Default carb trouble??
I am still having carb trouble. Right now i have six six t's adapter and k and n's with 150,155 main jet and gytr needles 3rd clip. still looks lean a little and feels really crappy and sputters on top end ,. I will try bigger main jets but just cant figure out why i would need so big. Plus one carb keeps leaking. Looks like it is coming from kind of high on the carb almost out of the mixture screw from the looks of it. cant figure it out exactly though.
Rudy
Old May 16, 2004 | 11:55 PM
sixsixT's Avatar
Have you checked the float level?
Old May 17, 2004 | 04:51 PM
Ward660R's Avatar
To add to the float level.
Try cleaning out all the passages in the carbs and make sure to clean the needle & seat area real well (fine steel wool works nice if you take the seat out). Maybe even try cleaning the tank's petcock out.
Do you have a pipe? If you do I can see you needing to richen up, if not I don't know.
Old May 17, 2004 | 07:41 PM
rudyraptor's Avatar
no pipe, checked float and it was about 1/4 inch above mating surface. Is that too high, i will try that in a little while.
Rudy
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
