11 thooth front sprocket???
Old May 17, 2004 | 01:37 AM
BURKEDADDY's Avatar
Default 11 thooth front sprocket???
do they make a front sproket for the raptor in a 11 tooth???
thanks
Old May 17, 2004 | 03:56 AM
jsyi's Avatar
why would u want an 11 tooth!
Old May 17, 2004 | 09:59 AM
warrior007's Avatar
I got a 10 tooth that'll fit if you want it.. someplace sent me the wrong one years ago.
Old May 17, 2004 | 10:27 AM
warwgn's Avatar
I think if you go that small your chain will have problems rotating, something about the size of links on a 520 chain. Not positive but you should find out for sure before you get one.
Old May 17, 2004 | 05:53 PM
FireFly's Avatar
Why would you want a 11tooth sprocket? It will bind your chain and eat your slider in no time.
Old May 17, 2004 | 05:55 PM
jsyi's Avatar
I would rethink getting a 10 or an 11 tooth man. i'd rather go huge in the rear than have messed up chains and sliders ....
Old May 17, 2004 | 07:30 PM
BURKEDADDY's Avatar
well i was running 12 tooth in the front with stock tires and i liked it but i got some new tires went from 20 inch to 22 inch and i want the bottom end back plus i just broke my front sprocket the other day so i have to replace it anyways why would it have problems rotating or eating up the slide?how big in the back can i go and still have an rear skidplate? should i get steel or aluminum?how many teeth in the back equals teeth in the front i heard its around 3 to 1 is this right?
thank you for all your help
Old May 17, 2004 | 07:33 PM
jsyi's Avatar
Like mentioned above the turn that the chain would have to make is kinda tight for a 520 or whatever... Im not sure how big you can go in the rear but it's better to go bigger rear...I think it is like 3 to 1... the smaller c/s sprocket will put a lot more wear as well.... I'd go w/ steel vs. aluminum...
Old May 17, 2004 | 08:30 PM
Bopeep's Avatar
I agree with everyone. Don't go smaller than a 12 tooth or you'll just eat up your chain, etc.
I'm running a 12 tooth front and a 42 tooth rear. The stock is 13/40, so if you want to change
your gear ratio, buy another 12 tooth and a larger rear sproket. Choose a size that meets
your needs.
Old May 17, 2004 | 09:49 PM
BURKEDADDY's Avatar
why would it eat up the chain???
what size is the nut on the sprocket?
