polaris lubricants
does anyone know what the polaris synthetic gear case lubricant is, as in atf, gear oil, or engine oil? the same with the premium demand drive hub fluid. I have a 2003 scrammy and I like to get my own fluids, as I am pretty sure that someone makes the fluids for Polaris like all other companies.
for hubs, you can get ATF fluid, such as Mobil 1 Automatic Transmission Fluid, it works fine. AMSOil syn. gear case lube will work for your gear case. there are others, but i dont know them. somebody else will come along
Like DG said, ATF type f or Mobil 1 synthetic ATF in the hubs. Amsoil Series 2000 Chaincase lube for the trans. I have also heard that Klotz makes a chaincase lube as well. Those are your only 2 substitutes. Engine oil, go with either Mobil 1 0W-40 "European Car Formula" or Amsoil 0W-40 "4 Stroke Formual" synthetic oil. Stay with the 0W-40. The engine was designed for that viscosity
