'03 raptor one way problems
Old May 18, 2004 | 06:06 PM
injun's Avatar
Default '03 raptor one way problems
I am almost positive that my one way is going out, when i press the start button it turns over but the starter doesnt engage. and when it does engage it makes a bad grinding sound and when it starts sometimes in nuetral it makes a bad grinding noise from inside the left case. Any comments on if i should get another oem one way or an L@A, and any thing i should watch out for when i crack open the case?
Old May 18, 2004 | 06:10 PM
1BADRAPTOR's Avatar
that be it , now your an official Yamaha owner..LOL i replaced mine with the L&A one way and it's solid as a rock now,,,
Old May 18, 2004 | 06:23 PM
injun's Avatar
Thanks for the advice, now to start tearing it down
Old May 18, 2004 | 06:35 PM
RaptorOwner's Avatar
Yes, my next one (which maybe soon) will be the L&A one. I am on my second OEM right now.
If I were you, do a search on the one way here or go to raptortranny.com and find out how to do this job.
Have fun doing it and watch out for that flywheel when it breaks loose!!
Old May 18, 2004 | 08:22 PM
Turtler's Avatar
My L&A should be here friday and will put it together on Saturday. Take the advice on the gear puller and buy the longer bolts, you will need them to pop the gear. Found that out for sure doing a friend of mines one way. No other surprises.
Old May 18, 2004 | 08:25 PM
Turtler's Avatar
One more thing, dont cheap out and skip swapping out the idler gear, that shaft should have significant chatter marks on it to warrant this part going to the scrap heap too. The whole kit cost me $255 from ripperracing.com
Old May 18, 2004 | 10:20 PM
fizzak's Avatar
I noticed the new idler gear had no needle bearings like the one in my 01. Strange they change to a bronze bearing.
As far as Raptortrany's guide:
I used the sears puller with the regular bolts since it was near impossible to find that size metric bolt around my town. Regular bolts with the puller and washers worked fine.
I used a propane torch to heat up the allen bolts on the old one-way before I removed them to soften the thread lock. I couldn't take the chance of stripping those.
I found it very useless to use the strapwrench to hold the crank while torquing the flywheel bolt. It slipped very easily. I even had someone stand on the brake and put it in gear but the clutch wouldn't hold it. (probably because I drained the oil?) I had very strong buddy use a oversized slotted screwdriver jarred into one of the teeth on the gear and against a protrusion on the block to hold that sucker while I torqued it. That was the hardest part.
Old May 19, 2004 | 10:49 AM
injun's Avatar
thanks for all the help guys, ill let yall know how it goes.
Old May 19, 2004 | 02:37 PM
garyc660R's Avatar
Here is the fix for the jumping flywheel problem + it will keep one from pulling the flywheel threads due too excessive force. Apply about 80-90 lbs of torque on the flywheel bolt. Next whap the puller a couple times with a large hammer and the flywheel will jump right off!! Harmonics is your friend...[img]i/expressions/face-icon-small-smile.gif[/img].
Gary
Old May 19, 2004 | 04:43 PM
Yes I put the 01 bearing in my 02 when I changed out mine. I sure did like the roller pin in there instead of the bronze shim.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
