mud-hole die out
Old Jul 31, 2000 | 01:32 PM
hockeydad's Avatar
Ihave a 2000 Kodiak and the last 3 good deep and wet mud bogs I Hit my machine spit, sputter and lost power. I had to shift to neutral and rev up motor and then claw out. Ant ideas on failure? coil wire,plug cap etc????
Old Aug 3, 2000 | 11:28 PM
TrailRider250's Avatar
It is probably because your four wheeler is sucking water, this causes sputtering and loss of power. You can locate the top of you air breather and see if this is dipping under. Once my trail boss sputtered every time i hit a mud puddle fast, and on closer inspection i realized the air breather was not properly connected to my carb, allowing it to suck water every time it splashed up.
Old Aug 4, 2000 | 11:15 AM
JHAM's Avatar
Mine did that and someone on the forum advised me to fill the spark plug boot with dielectric grease. I did that and have had no problems since. I bought it at Advance auto. The guy who gave me that tip said all serious mud riders do this...
Old Aug 4, 2000 | 06:54 PM
adding the grease waterproofs the plug, thats a good idea.
Old Aug 4, 2000 | 10:08 PM
eveready299's Avatar
I had the same problem and tightened the rubber boot from the carb. and it seems to have helped no sputter yet. I am going to try the dielectric grease idea too!!
Old Aug 6, 2000 | 04:01 PM
Ozark's Avatar
Be sure you check the clamps for the air intake on the tranny. I found mine to be quite loose, as well as the exhaust clamp for the tranny. The die electric grease is a good idea for any electrical connection that could get wet
Old Aug 6, 2000 | 04:30 PM
TAZsGRIZZ's Avatar
I know what the problem is and I am not going to tell you.
TAZ
MountainMan31274
Oct 6, 2006 11:26 PM
chainman
Feb 20, 2002 12:33 PM
andyems
Feb 12, 2002 08:39 AM
atvnewbe
Mar 4, 2001 08:20 AM
