400ex brake troubles!
Old May 19, 2004 | 04:33 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Default 400ex brake troubles!
I replaced my front brakes on my 400ex recently, and they slow down the quad but won't lock em up like it should. I bled them thinking there was air in the lines, but that did not help. The break lever comes all the way back to the bars to.
Any suggestions or help will be appreciated.
Old May 19, 2004 | 06:15 PM
reconbasher's Avatar
i hand vacum pump works the best at bleeding brakes on these. sounds like air in the system still. make sure you put the resevor cap back on tight.
Old May 19, 2004 | 06:22 PM
Eric250EX's Avatar
cheack your lines to. also the brake roater could be bent a tad, but i dought that since u replaced your breaks recently,
Old May 19, 2004 | 10:01 PM
tprender's Avatar
If you still have the stock rubber lines on, the lines are expanding with the pulling of the lever. It looks like it is time to steel steel front lines. But, 1st make sure that you dont have air in the old line.
Old May 19, 2004 | 10:23 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I have bled the **** out of them, Im pretty sure there is no air in the lines. Could there be something wrong in the master cylinder causing it not to have full pressure?
Old May 20, 2004 | 09:00 AM
tprender's Avatar
It might be, but you most likey need new lines. If the lever feel goodsbut you can pull it back like nothing is working, Then the old lines need to be replaced. I had this happen with my 400, rplace the lines and the front brakes worked good after that.
MikeyBoyesq
Sep 22, 2015 10:02 AM
1ArmBandit
Sep 8, 2015 08:59 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
