Cleaning the K&N Filter
Old May 20, 2004 | 12:52 AM
RAJ's Avatar
RAJ
Default Cleaning the K&N Filter
I have not had the quad out since I got back from Hatfield & McCoys....well I got it out today between the rain showers,to clean it back up, and was looking at my filter.....DAG ON it is dirty. I known I have to use K&N oil, so do I just spray it down and then blow it out with the air hose?
Old May 20, 2004 | 01:08 AM
RAJ's Avatar
RAJ
Should I just throw it across the field and buy a new one? LOL[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 20, 2004 | 01:18 AM
BigBadScrambler's Avatar
Do you have the recharge kit? It has a special cleaner in it. Otherwise, Modquad said that he uses the Simple Green to clean it. You know that it is clean when it is a grayish color. Also, remove any particles that you might see. I use a garden hose to spray it off. Then let it completely air dry (dont put heat on it). Once it is dry, spray the K&N oil on. Give it a good soaking. Then let that dry and you are good to go.
Old May 20, 2004 | 01:34 AM
mudmaster250's Avatar
i dont have time to get filter cleaner so would like a dish soap and a few good washings work ok for now and then spray it with oil and let it dry, oh ya its a foam twin air if that changes anything
Old May 20, 2004 | 01:35 AM
MnFriesen's Avatar
with all the talk about simply green lately I think I might buy stock in it!! lol
Old May 20, 2004 | 01:40 AM
LOL. Simple Green is the shiz nit!!!
modquad's Avatar
Formula 409 is basically the same as the K&N cleaner. Be careful when "blasting" these filters. They are construtced of cotton gauze. Sometimes with a blow-gun, you can very gently blow out from inside the filter. Be careful. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 20, 2004 | 01:45 AM
Twin air has the step by step cleaning procedure on their website. Click on the "Tips" section. They recommend soaking the filter in "Soap and Water, Simple Green or Air Filter Cleaner"
Old May 20, 2004 | 01:47 AM
ok cool, thanks jason
Old May 20, 2004 | 02:02 AM
RAJ's Avatar
RAJ
Thanks guys, I will try the K&N recharge kit...that is if it aint to much money, need to save so I can buy more mods[img]i/expressions/face-icon-small-happy.gif[/img] LOL
