sticking intake valve
Old May 20, 2004 | 09:49 PM
bugracer's Avatar
Default sticking intake valve
the intake valve on my '84 honda 110 atc just started sticking in the open/ partially open position after I shut it down and the engine is hot. When the engine cools down it pops shuts and starts and runs perfect until I turn off the engine,and then immediatelly the valve sticks in whatever position the valve is in. I can tap on the rocker and it will pop back up after a couple of whacks. I've since changed the oil and tried a super type lubricant.............still does it though. Anyone know any tricks here?I did'nt want to pull the head if I don't have to. The sole purpose of this 110 is a tow vehicle for a drag car. Thanks..............
Old May 20, 2004 | 11:27 PM
KNOWSALOT's Avatar
The Facility
There isn't any permanent fix without replacing the valve.
It isn't but a 45 minute job on a 110 taking your time. You can get the gaskets and the valve for under $25
Old May 21, 2004 | 07:37 PM
bugracer's Avatar
Thanks for the comeback...........why does the valve need replacing? what happens to the valve ? thanks again
Chuck
Old May 21, 2004 | 07:44 PM
bugracer's Avatar
I don't have a shop manual.................. I'm a decent mech,anything I need to be extra careful about,like the valve/cam timing,if so,any tips, and what are the torque specs?
thanks again, Chuck
Old May 21, 2004 | 08:25 PM
sharpie's Avatar
i did it a while back on a trail 90 without my manual. realy it is simple. find TDC, pull off the cover over the points, take the bolt out of the end of the cam, and take out the screws under the little timing plate and remove that whole assembly. then your cam should slid right out after you take the bolts off of the sprocket. be carefull to not let the cam chain come off of the sprocket or you will be in alot of trouble. then you can take off the 4 nuts and slid the whole head off. from there your on your own, i've never gottin in to the rest of the process. remember that i may be wrong or i may have missed a step. this is all from memory and i have no idea if this is the right way to do it. correct me if i'm wrong. hope this helps.
Old May 22, 2004 | 10:02 PM
dzzy's Avatar
Could be a guide problem too, or a carbon buildup on both the valve and especially the guide. Check for anything fishy like a cracked or broken guide. If all is well there, you'll definitely want to ream the guide. It takes a 5.5 mm reamer, most Honda dealers should be able to do it in a few minutes once the head is off. You may want to replace the valve regardless, the valve face on Honda intake valves of that vintage do get a big grooved, but of course that wouldn't explain your sticking. The exhaust valves last a lot longer, they must be hardened to a greater degree. If you pull the front wheel and fender off, it's very easy to remove the head, pretty much like sharpie said.
Old May 23, 2004 | 01:13 AM
bugracer's Avatar
Thanks all for all the info and help......................I'm gonna take it apart tomorrow............hopefully I can fix it then. Thanx..........
Chuck '72 superpro bug....(former 1/8 mile "C" sedan record holder@ 6.68et,goin for 6.60et)
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
Sassinm1
Sep 30, 2015 04:23 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
