who all makes 400ex big bore kits? websites?
Old Jul 31, 2000 | 10:55 PM
allnamesaretaken's Avatar
who all makes 400 ex big bore kits? I am thinking of sending my motor to ct racing for a 440 kit, anyone else have them? curtis sparks have one? I also want to do a cam and the head ported with a pipe. any ideas???
Old Jul 31, 2000 | 11:20 PM
hakmazter's Avatar
IMS products is the maker of all big bore kits I believe. As far as I know, they make the sleeves, then they package a JE or Wiseco piston with it and some gaskets and send it off for resale to White Bros, Parts Unlimited, and every other dealer under the sun.
Old Aug 1, 2000 | 12:27 AM
how many bores are there on a big bore kit?
Old Aug 1, 2000 | 01:22 AM
puddding's Avatar
is that a tirck question?
kinda like
how much wood could a wood chuck chuck, if a wood chuck could chuck wood.....you don't know how hard that was to type!
Old Aug 1, 2000 | 11:46 AM
Slyder's Avatar
Nobody "makes" 440 kits. These companies assemble them and charge you for it. Wiseco and JE make the 89mm pistons. Advanced Sleeve and LA Sleeve make the 89mm sleeves. Companies like Cometic make the gaskets. You can order all the stuff from Wiseco yourself and spend $199 plus shipping, or you can give someone like CT or IMS almost $400 just so they can put the three pieces in a box and call it a kit.
Old Aug 1, 2000 | 05:23 PM
bpace's Avatar
IMS makes two kits. One kit has room to overbore one time and the other has room for two overbores. The one that allows for two overbores is slghtly less than a true 440 kit and is more for the average trail rider whereas the other is more for the racer market.
Old Aug 1, 2000 | 06:53 PM
mudmachine's Avatar
RCR (Ritter Cycle Racing) has one.. I think his uses the JE piston. Thumper Racing has one.. Both have full knowledge of how to port the head and set it up for the increased compression and displacement. Both have machine shop services. I think Thumper uses the Honda High-performance camshafts that are originally for the 400cc dirtbike.. Im not sure what RCR uses.. Both are GREAT companies with excellent service reputations... I would NOT go with a Mickey Onelap set-up (FST) While i havent personally dealt with him, theres GOT to bea a reason SO MANY people bad mouth that place.
Old Aug 2, 2000 | 06:06 PM
Giz400ex's Avatar
LRD makes a 440 and a 460 for the ex!! I believe there website is still under construction though!!
Reactant
Mar 30, 2022 02:08 AM
95wolv
Jul 21, 2015 12:25 PM
Sandman2.0
Jul 21, 2015 09:03 AM
toonces
Jul 11, 2015 12:01 PM
yambam13
Jul 4, 2015 01:49 PM
