400ex blowing smoke at full throttle and when I let off the gas
Old May 22, 2004 | 04:24 AM
420EX's Avatar
Default 400ex blowing smoke at full throttle and when I let off the gas
A few weeks ago I was riding with some friends at the dunes and they were saying my 440 was blowing white smoke at full throttle and when I let off the gas, I thaught they were full of **** until I looked at it today and it actually was doing that. What could be wrong with it? I just installed a new piston and had it bored but it was doing it before that too. My other 440EX motor did the same thing, even after I replaced the valve seals, what in the hell is wrong with this thing?
Old May 22, 2004 | 01:36 PM
hondarider300's Avatar
piston rings might be bad, or it could be running rich, but when its rich its usually darker smoke i think
Old May 22, 2004 | 02:53 PM
cals400ex's Avatar
i think this is somewhat normal for the 400ex's. they all seem to use a little oil when ran really hard. when i made the switch to mobil 1 15w-50, the problem greatly diminished.
Old May 23, 2004 | 03:05 AM
420EX's Avatar
it's running a little rich yes but thats not the cause of the smoke, this is definitly oil burning smoke. the rings and bore are brand new so that cant be it. I might try running 20w 50 but im not sure if that would be such a good idea as it may cause my clutch to slip. I used to run 20w 50 last summer with my old motor but that was because it knocked and smoked but I dont think the clutch slipped, I'll try running it again and see if that solves my problem. thanks for the help.
Old May 24, 2004 | 12:25 AM
trailrider500's Avatar
Now what did i tell you?????? Damn right it does burn oil... looks like your full of **** this time bud[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 24, 2004 | 01:17 AM
mudblaster's Avatar
i dont know alot about atv motors but when you rebuild a car motor depending on the type of rings you put in it might take some time for the rings to seat.
Old May 24, 2004 | 02:18 PM
cals400ex's Avatar
i don't have any clutch problems with full synthetic mobil 1 15w-50. i do believe the other oils offered by mobil 1 are certified and aren't recommended for wet clutches.
Old May 24, 2004 | 05:53 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I think it is your valve seals, they are very cheap.
Old May 24, 2004 | 06:23 PM
420EX's Avatar
my other 440 motor did the same thing and it had brand new valve seals, i think I'll just run 20w 50 pennzoil like I did last summer
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
blpersinger
Jul 15, 2015 09:56 PM
Sjrpp
Jul 5, 2015 09:04 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
