Cheap Warrior mods
Old Jul 31, 2000 | 11:11 PM
Mimcgl2's Avatar
I'm a beginner mechanic so what are some easy modifications I can do to my warrior without paying a lot of money.
Old Jul 31, 2000 | 11:24 PM
REDYAM's Avatar
add a pipe and get a prodesign air filter with k&n and rejet the carb
Old Jul 31, 2000 | 11:25 PM
Mimcgl2's Avatar
How do I jet the carb?
Old Jul 31, 2000 | 11:45 PM
REDYAM's Avatar
your pilot jet does idle to 1/4 jet needle does 1/4 to 3/4 and main jet does top end of throttle go up on main about 2 or 3 then back down untill throttle is chrisp last check spark plug atfull throttle and shut engine off and coast in and check it
i forgot if it backfires it is lean and if it is lean dont ride it even if you think its fine you must check spark plug
the main and pilot are in the float bowl and the needle is at the end of the throttle cable
Old Aug 1, 2000 | 12:30 AM
REDYAM's Avatar
the whole idea is to get the air in and out of the engine as soon as possible anytime you modify a engine you must check jetting
Old Aug 2, 2000 | 01:16 AM
Indianoutlaw's Avatar
Could you recommend a pipe/s.a. to us? I would like to start here and make more "improvements(?)" later. Is it best to go ahead and get the head pipe too right now, or wait till the engine needs it? Thanks!
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Sep 23, 2015 06:23 AM
01ssls1
Sep 22, 2015 06:50 AM
PrairieDog126
Sep 16, 2015 01:33 PM
