sea level 686 jetting solution...100 octane
I need some jetting help with my new 686 jetting. I am running a full CT pipe setup w/K&N pro flow. The airbox lid is off. I have a stage II cam and 11:1 piston. Like the title, I am running at sea level and 100 octane. Please give your opinions...
Believe me, if I had the money, I would definitely go with the FCR's. I've heard of people modifying their stock carbs. What all is done to the stockers when they are modified? Will 195/200 and bigger pilot jets not work with my setup with out your recommendation?
try a dyno jet kit, use their needles and springs set up how they suggest, but run 27.5 piolt jets, turn your a/f screw out 3 turns, and start with 185 and 190 main jets from dyno jet, that is probally the best starting point to go with. After that run it for awhile so you can get a good reading on your plug and adjust up or down from there. Or start from there and leave all your plastic off and just go up and down on your jets and make some hard runs to find out which jets pull best.
Pic 1 stocker on the right
Pic 2 stocker on the left
I already have a dual feed setup on my carbs and I was going to install the 185/190 mains and 27.5 pilots. My jet kit is from CT and my needle clips are 3 from the top. I was going to start off with this unless otherwise conviced.
