450r oil change
Old May 23, 2004 | 05:18 PM
TractorPacker's Avatar
Do you have a balloon?
Default 450r oil change
I don't have a book.I got 2 oils and one filter. The engine side is under control. My question is on the tranny side. Is the drain on the bottom left or rear of the engine, and the full mark the phillips screw in the middle?
Old May 23, 2004 | 05:23 PM
RoughRider01's Avatar
Yup the drain is on the bottom left and the check screw is the phillips screw. I used a socket to get the check screw off, didnt feel like stripping it with a screwdriver. You want to let the engine run for about 5 minutes, turn it off then let sit for a couple minutes. A little bit of oil should come out of the check screw, if not add more slowly til it does.
Old May 23, 2004 | 05:25 PM
Right on Roughrider thank-you. I thought that was it but its easier to ask then fix a screw up.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
