350x Swingarm
Old May 23, 2004 | 09:24 PM
thebutelr's Avatar
Default 350x Swingarm
On my 350x the chain tensioner is broken in half and it is very hard to tighten the chain now (it was like that when i got it), and i was wondering if i bought a new swingarm carrier it would have a new tensioner on it? Also how much will a brand new carrier cost me? Oh another question, can i get a new inner air filter for it or would i have to go used (the metal screening inside the actual air filter)? Thanks.
Old May 23, 2004 | 11:23 PM
Blazerone22's Avatar
Yeah, you tighen the chain by turning the carrier, The carrier is ecentric, I went with a Rad double row carrier for around 160.00 on the aircleaner pick up a K&N or a foam UNI-filter I prefer the unifilter in dusty areas. You just clamp on the new filter and toss the stock filter.rad carrier
Old May 24, 2004 | 02:38 PM
thebutelr's Avatar
Hey, what is the website for that carrier you got? And also can i just forget about buying one of those stock metal screens that go inside of the airfilter if i get a K&N? Oh yeah, what kind of exhaust are you running on your 350 (mine is gonna get replaced sometime this summer)?
Old May 24, 2004 | 04:08 PM
ThrashAndCrash's Avatar
can you use a lage pair of channel locks for the time beeing??? the stock carrier is close to $220 on bike bandit
Old May 24, 2004 | 05:05 PM
thebutelr's Avatar
Is the stock one better than a after market carrier? Also, i can use the spanner wrench that came with it to tighten the chain quite easily but there is something missing in it that makes the chain go loose after not riding very long or its stretching the **** out of my chain.
Old May 25, 2004 | 03:35 AM
most of the time a aftermarket is pretty darn good, usuall made lighter than the stock one. Adjust your chain, then make with a marker a line on the carrier and one on the swingarm. I bet your carrier is just rotating back. Then just tighten the pinch bolts tighter or clean the surfaces where they meet. If that does not work you may need to file down between the pinch bolts to get a tighter fit. I try everything I can to make it safe as cheap as possible before I spend $200.
STLyamwar
Jul 25, 2020 04:44 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
scottdubya83
Aug 29, 2015 04:08 PM
95wolv
Jul 21, 2015 12:25 PM
