raptor 660 in dirtwheels
Old May 24, 2004 | 02:35 PM
clover's Avatar
Default raptor 660 in dirtwheels
did anyone see the test on it in the latest dirtwheels mag (june).Anyways they said a stock raptor with only gearing changes is easily capable of 95mph.Thats pretty dang fast if thats true,but i don't believe it.
Old May 24, 2004 | 02:58 PM
nickxc's Avatar
I did read that but I think its crazy. I guess you cant believe everything you read. Well maybe if you change the gearing and put it in the back of your dodge hemi it might hit 95mph
Old May 24, 2004 | 03:16 PM
FooBar's Avatar
it should be capable of more than that in stock gearing. all you need is a really big cliff to push it off of. i estimate that a raptor should have a terminal velocity of about 120 mph during free fall.
Old May 24, 2004 | 03:40 PM
Voodoothenoob's Avatar
y would it not be capable? not enough horsepower?
what are the shift speeds on a raptor
1st: 15
2nd:35
3rd: 55
4th: 70
top speed 80+
those above #'s are not based off of fact or experience, just pulled out of a hat, but does any1 here have a educated guess on what they should be?
Old May 24, 2004 | 03:45 PM
YamahaRiderOnly's Avatar
It is capable of hitting 95 mph with gearing change but it will take a year to get there. Pretty much any quad could have a higher top speed if you gear it for that.
Old May 24, 2004 | 04:09 PM
BALDMIKE's Avatar
A Raptor 660 with a high gear ratio could hit 95 but like said above it would take forever to get there and you would have NO low end at all........
Old May 24, 2004 | 05:51 PM
warwgn's Avatar
stock my raptor hit 67 at 6000 ft so with a gear change at sea level you could get 85-95 without too much trouble, but you will sacrafice alot of bottom end.
Old May 24, 2004 | 06:23 PM
400EXTC's Avatar
I hear a lot of people talking about gearing, and they make it sound like if you keep swaping sprockets to make the ratio higher you will continue to increase the top speed. You can only go so high before your engine will not be capable of pulling those tall gears high in the rpm range.
For example, I had a mustang that would run faster in 4th gear than 5th gear because the 5th gear was so high the engine did not have the power to pull much past 4000 rpm. it would pull 5th gear to like 6200.
Old May 24, 2004 | 06:27 PM
dirtrooster's Avatar
I put a 16 tooth sprocket on and in 5th she is hard to catch. I will speedo it next time.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
