V fan running ? Need your input
Old May 26, 2004 | 12:33 AM
Banshee2001BW's Avatar
Default V fan running ? Need your input
I bought a v for my girlfriend, and I rode it last weekend and I notice that the fan was running a bit when I was ridding but what suprised me, is when I shut the motor off. I could not beleive how long the fan was running ( it seemed like 3 to 4 minutes). It was about 74 degrees out I am woundering wath it will do when I ride it in the 85 degrees. My question is, is your V the same or should I have it checked.
Thank You
REG
Old May 26, 2004 | 12:35 AM
MnFriesen's Avatar
Do a search on this....I think there is some sort coolent people use to keep the enigine cooler...I think it might be waterwetter or something like that
Old May 26, 2004 | 01:01 AM
HappywithVForce's Avatar
If it is new, the fan will come on a bit more. When it gets broke in the fan will come on less. I was also suprised that the fan was on so much.
Old May 26, 2004 | 10:48 AM
mt's Avatar
mt
The V runs hot, even when broke in. I just bought a in-line cooler from Rockymtn, also waterwetter and even make products for cooling.
Old May 26, 2004 | 04:15 PM
hazmat1800's Avatar
You might try EVANS COOLANT it works really well. Since I have installed it in my V-Force the fan dosen't come on as much or runs as long after shutoff. You can order it at EVANS.com
Old May 26, 2004 | 04:58 PM
Pkspawn's Avatar
Couldn't it be bad for your engine to run fairly cool where the fan is almost never coming on?
Due to an accident, I upgraded to the IMS radiator and installed a fluidyne electric fan.. I can hear the fan kick on and off durning long trail rides, and normally will run for about 30-45 seconds after i stop or turn off the bike. I would imagine if I used something like Evan's Coolant, that the fan would very rarely come on, or may not come on again. Would this be good that the engine is running that cool? I heard someone say that the engines could "cold seize" when they are not allowed to run "at temp"... any truth to this?
Old May 26, 2004 | 05:09 PM
XC800's Avatar
Talk to Alltoys and get a new CDI. The timing change will make the bike run MUCH cooler. My fan almost never comes on, even after hauling my a$$ up a mountain. Also you will get more RPM and no reverse limiter. Price is cheap too!
Frisky2050
Apr 9, 2020 11:19 AM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
Rooky
10
Jun 23, 2015 09:35 PM
blackwolf
Jun 7, 2015 08:05 AM
Schneider
Jun 4, 2015 11:37 AM
