Do I really need to Repack?
Old May 27, 2004 | 11:50 AM
YamRap's Avatar
Default Do I really need to Repack?
Aftermarket exhausts always say to repack the silencer packing every 20-30 hours or so. Is this really needed becuase I have talked to a lot of people who don't bother repacking and they say they don't lose much, if any horsepower and that the noise is the same.
Old May 27, 2004 | 04:19 PM
Vinson581's Avatar
i would repack i did to rm's fmf, and wow what a difference it made, it seemed alot quicker, and alot quieter, packing is cheap so repack, and dont go by hours go by if there is almost none in there repack, and if you have 50hrs on it for example and its full, leave the packing alone.
Old May 27, 2004 | 04:56 PM
LotusPosition's Avatar
What would be the best way to get those steel rivets out of an aluminum can? Drill them or grind them? I wanna repack without trashing the muffler.
Old May 27, 2004 | 05:02 PM
Vinson581's Avatar
hmm, is it 4 or 2 i dont think i would cut rivets on a can, there arent 3 allen head screws on it? on both my fmf, and hmf there a screws, and that takes the end cap off, and reveals the packing, i dont really think you need to repack a 4 stroke pipe, because the exhaust is so "clean" it doesnt burn the packing away like on a two stroke, because of all the oil in 2 strokes exhaust.
Old May 27, 2004 | 08:24 PM
It's a 4 stroke. Many pipes, like my R4 have riveted ends. Also, most 4 stroke pipes tell you to repack them at 20-30 hr intervals
One thing I know for sure, it won't have riveted ends once I am done with it!
Old May 27, 2004 | 08:56 PM
Vinson581's Avatar
i wouldnt bother to repack it then, being it is rivited, my hmf, has the 3 screws, and i have inspected after 1000mi the packing look new, hmf also stands a 10yr warrenty behind it, so i guess you never need to repack em [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 28, 2004 | 12:47 AM
RedGoblin's Avatar
So is the new advertising scheme for the FMF Powerline claiming "no need to repack" just a trick then? It has no packing, but is that really necessary to find a way to not use any packing?
Old May 28, 2004 | 08:30 AM
No, it is not a trick. Some pipes have some chambering and such that eliminates packing material.
Old May 28, 2004 | 11:00 AM
RedGoblin's Avatar
I guess I phrased that wrong. I believe that they don't have a packing material, but is it really that significant of a feature on the pipe? I mean, is it a huge advantage over traditional packing or is regular packing going to last just as long as this special pipe?
Old May 28, 2004 | 11:02 AM
Vinson581's Avatar
instead of packing to quiet it down, it has different pieces of metal deflecting the gasses inside the can, and therfore when noises hit each other they cancel, this is what that new hmf eco system is all about.
