Sport Quads Discussions on sport quads.
tires
Old May 28, 2004 | 09:33 PM
yamahas4life's Avatar
Default tires
i was wondering what tires for the rear should i get. i do mostly trail riding and riding on semi loose sand and packed gravel. what tires should i get the razrs or the holeshots thanks
Old May 28, 2004 | 10:28 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default tires
What kind of machine? I would recommend a different tire for a Blaster (lighter), than I would for a Raptor! The new Holeshot H-D, should be an excellent eastern trail tire.
Old May 28, 2004 | 10:52 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Default tires
JMO, but I don't think that will make a good sand tire.
Old May 29, 2004 | 02:53 AM
Red Rider
Default tires
The Holeshot H-D does very well in the sand (we have a little sand here in So. Calif.!). The ***** are widely spaced and deep, so the tire gets a good bite in soft stuff. Where it doesn't do so great, is on desert hardpack. Now, I am not recommending this as a tire for the dunes, but rather something like running up a sand wash on a cross-country ride.
Old May 29, 2004 | 08:33 AM
Default tires
i have a blaster so does that make any difference on your choice. dont foget some of it will be for trail riding to. the sand i ride in is at a pit. not dunes
Old May 29, 2004 | 09:45 AM
Red Rider
Default tires
See your other post. I recommend the Standard Holeshots for the little Blaster. I had not ridden a Blaster in years, but I rode a friends the other day. Brought back a lot of memories! Great fun little bike!
Old May 29, 2004 | 10:46 PM
Default tires
what tires wear slower the holshots or the razr's thanks
Old Jun 2, 2004 | 04:59 PM
Ordie1's Avatar
Default tires
Holeshots wear out quicker. They are designed for soft dirt. Hence, the ***** are softer for a better grip. You take them on a trail and they'll wear out about 4 times quicker than the Razrs. If you get the Razrs, don't worry about getting the II's or MX's. Get the plain old Razr's. Don't spend more money on something that you don't really need. You might also consider the Carlisle Truf Tamers. A little cheaper than the Maxxis, but not quite as great for life length. But for the kind of riding that you do, I would go with the Turf Tamers, or Razrs. Razr's will give you quite a bit more bite on those trails too.
Old Jun 2, 2004 | 05:26 PM
Karnage's Avatar
Default tires
whats the difference in razr's and razr 2's anyways?
Old Jun 3, 2004 | 07:40 PM
speeeedy's Avatar
Default tires
razr 2 have alot bigger ***** and only come in 6 ply and 30$ more per tire than the razr and 20 more per tire for the 6 ply razr.
