Raptor 350
Old May 28, 2004 | 11:06 PM
SethL's Avatar
Default Raptor 350
Has anyone raced the new raptor yet? I'm thinking about doing 4 stroke begginner at the local track after I add a pipe, high flow filter and a jet kit. Anyone have anything else to add or opinions about racing the raptor
Old May 29, 2004 | 12:14 AM
clover's Avatar
Default Raptor 350
I believe it should do pretty good since the new suspension upgrades,with a pipe filtered and rejetted you should be able to keep up with the modded 300ex with the bore kits.
Old May 31, 2004 | 12:17 PM
SethL's Avatar
Default Raptor 350
What about re-gearing? What set up would work best on a motocross style track
Old May 31, 2004 | 12:51 PM
clover's Avatar
Default Raptor 350
i believe dropping a tooth on the front might work pretty well it will help you get a better holeshot.Also if you get new tires for mx,i would run holeshot mx tires.
Old May 31, 2004 | 12:59 PM
SpeedDemon13's Avatar
Default Raptor 350
hey sethl, how old are you? And i hope u find the mods u need and i hope u do good.
Old May 31, 2004 | 01:30 PM
SethL's Avatar
Default Raptor 350
Alright thanks for all the replys, but how many teeth are on the stock sprocket?. I'm 14 now but by the time the track opens up (largest indoor in USA) I'll be 15. Hopefully some more mods will become available before then
Old Jun 2, 2004 | 01:22 AM
Coyotechaser's Avatar
Default Raptor 350
Some of the Warrior mods should work. Shouldn't they? Same motor.
Old Jun 2, 2004 | 11:08 PM
clover's Avatar
Default Raptor 350
yeah the warrior exhaust,air filters are all the same and i'm sure inside the engine is to.the rear sprocket has 38 teeth and the front i think is a 13 tooth,but not sure it could be 12 i'll have to check on it.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
