400ex ac pro-peg nerfs
Old May 29, 2004 | 08:52 PM
MidLifeRider's Avatar
Default 400ex ac pro-peg nerfs
I am thinking about purchasing a set of these nerfs for my EX. How is the position of the pegs, are they pretty much in the same position of the standard pegs?
Old May 30, 2004 | 12:38 AM
clover's Avatar
i'd say there positioned the same as the regular foot pegs,because they should bolt right on replacing the stock ones.
Old May 30, 2004 | 01:54 AM
1BAD250R's Avatar
IMO, I would skip on the AC pro-pegs and get the new X-Factor pro-pegs. They cost $70 more but instead of a cheesy aluminum peg like on the AC that will eventually wear down you get steel pegs that are double wide and come with a kick-up extension.
Old May 30, 2004 | 01:22 PM
NotuRaptor2's Avatar
Actually, the footpegs will be 1/4" higher with the AC Propegs. 1BAD250R makes a good point about the X-factor nerfs unless weight is your main concern. The AC are extremely light weight. Personally, I use an old DG design that have heavy-duty steel pegs that are 1" lower and moved back about 3/4". I feel the added weight is more than made up by the lower center of gravity.
Old May 31, 2004 | 01:55 AM
MTX's Avatar
MTX
i would just go with AC pro pegs
ac pro pegs - $189 @ gopartsdirect.com
x-factor pro pegs $279 @ x-factor
Old May 31, 2004 | 02:24 PM
1BAD250R's Avatar
True the AC pegs are at a low price, but they wear down quickly. A friend of mine had them on his R and they wore down after two seasons and he had to buy new pegs and fabricate them into the nerf bar. The X-Factors may cost more but they are well worth it.
Valder
Nov 28, 2020 07:38 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
