got my big red fixed but need more help??
Old May 30, 2004 | 10:11 PM
loveotride123456789's Avatar
Default got my big red fixed but need more help??
how do you tighen the cam chain teners and how do u know where how tight to get it
thanks for the help nick
Old May 31, 2004 | 09:21 AM
hondawontdie's Avatar
I am not sure about the 86 but on the 84 there is a cam chain adjustment bolt on the left hand side it is covered by a rubber cap. There is a cap that unscrews the will show when the chain is adjusted properly. On the 84 it is a huge slotted cap on the same side as the adjustment screw. You remove the cap and then losen the adjustment bolt while the engine is running, rev the engine to 1500 rpm and tighten the bolt. There is a letter under the cap that will line up when it is properly tightened.
not sure if it will help........
ultangler
Nov 30, 2024 01:35 AM
95wolv
Sep 27, 2024 12:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Matt123
Sep 29, 2015 01:29 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
