Lack of Power at 7500-8000ft?
Old May 31, 2004 | 03:01 AM
RogerL's Avatar
Default Lack of Power at 7500-8000ft?
Pulled the plug on the 2003 400i auto and noticed its running too rich...very black. I normally run about 4500-6500ft range. Went to some taller hills and run around some trees (90 miles one way trip just to be close to trees) I was close to 8K ft a few times and mostly ran about 7500ft for about 18 miles.
Do I need to change my jet and needle for running at higher elevation? If so, how hard is it to do. Some time later this year I was going to grand mesa, colorado and run at about 10,200 ft ele.
Is there a kit that can can jet sizes in the field?
Thanks
Roger
Old May 31, 2004 | 03:58 AM
FAStCAT7806's Avatar
Originally posted by: snox314
If you ride alot above 4000' or live around that elevation have the dealer set the carburetor and clutches to the AC high elevation specs, this will make a nice improvement in performance and fuel economy.
I hope this helps..
Old May 31, 2004 | 08:44 AM
DaveB's Avatar
On my 03 400i, the main jet was changed to a 145 and the fuel screw to 1.5 turns out (was 2.5 turns out from the factory). This cured the lack of power and surging at higher elevations.
Old Jun 1, 2004 | 01:51 AM
snox314's Avatar
RogerL,
Put the same setup that DaveB is running in his machine, and you will be fine for 4-8000" feet. Also go talk to your dealer about the hi-alt. clutch mod.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
antiguogrumete
Sep 5, 2015 03:41 AM
