300ex questions
Old May 31, 2004 | 12:42 PM
wheelieboy's Avatar
Default 300ex questions
Dear Fellow Riders,
OK, I just got back from a trip to the Jelloco Mountains and I ran into a problem. While I was riding I found out that
on my 300ex I had to pump my front breaks about 5 times to build enough pressure to get them to work. Do you have any idea
what is causingthat and how to fix it?
Also while we were on the trip we noticed that my left front tire was wobblin' so we started to look at it and we found
out that bearing had busted and it was causing the rim to be eatin up by the nut. eventually the nut busted off at camp and and I
was stuck riding double for the rest of the trip. (bad luck! [img]i/expressions/face-icon-small-tongue.gif[/img] )
I was also wondering what would be a few good mods to put on to my 300ex. I've already installed a white bros. muffler and K&N air filter just tell me anything you think of.
Jake
Old May 31, 2004 | 02:52 PM
wheelieboy's Avatar
C-mon Guys I need some help
Old May 31, 2004 | 07:00 PM
BRAD14's Avatar
you might want to check your brake fluid and your master cylender.you might want to get a 14t front sprocket for a little more topen d and some 20in back tires.
Old May 31, 2004 | 09:50 PM
wheelieboy's Avatar
I checked the brake fluid and it is all full. Where is the master cylinder located.
Old Jun 1, 2004 | 12:20 AM
BRAD14's Avatar
its right behind the steering steem between two of the frame rails bolted on top of another that connects the two its between(i think thats the master cylender)get your self a shop maual it will helpyoualot.
Old Jun 1, 2004 | 10:17 AM
wheelieboy's Avatar
What would i be looking for that is wrong with it? Also what does the master cylinder do?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 1, 2004 | 01:40 PM
BRAD14's Avatar
you would want to go ahead and buy a master cylender rebuild kit and i forgot to tell you to check your brake pads.The rear pads on mine went out and it feels like there is no pressure.The master cylender pumps the brake fluid to the brakes i think.
Old Jun 1, 2004 | 01:57 PM
wheelieboy's Avatar
The brake pads are fine and the master cylinder would effect both back and front this is just the front.
Old Jun 1, 2004 | 03:29 PM
BRAD14's Avatar
there are two master cylenders.the front one is in the place i described to you earlier.The rear master cylender is bolter to the frame right above your rear brake pedal.
bigred20653
Oct 2, 2015 10:05 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
