Warrior Starting Trouble!
OK it is getting spark, I thought the plug was destroyed I changed it and nothing. Sometimes, It will start and as long as it's warmed up, it will fire right back up. But It won't start at all right now. It turns over and gets spark, just doesn't start. It's getting gas I'm sure because the plug is soaked with it and It will run sometimes and it runs perfect. And Like I said it starts right up after it's warm. I haven't tried drifting it but I dunno....what the hell could be the problem here guys.
Thanks,
Warrior68Man
Thanks,
Warrior68Man
does your starter kick in mabye it went try to see if there any leaks for gas or air going into the motor or on the rubber mounts between the cabr and head. Also how is the compression when it runs?
