DS shock spring sag?
Old Jun 2, 2004 | 12:59 AM
TheChosenOne's Avatar
Default DS shock spring sag?
I have the Baja X, and it is now just under 7 months old. We do a lot of jumping, so we tightened up my suspension pretty tight, and it handled very well. However, I was reading that you could loosen off the front suspension all the way and then dump the cluth in second to drag and manage it. I was curious as to if this were true or not, so I decided to try it. I loosened off the suspension on the front, and as I got about 1-2 inches from the top, the spring would no longer come up, it just rattled aroung on the shock. I was wondering if this were normal, and If from having my springs so tight for that long if I permanantly compressed them. Can I buy just new springs? What suggestions do you guys have?
PS when I loosened the springs to where they jst touched, the overall ride was incredable, much easier to handle, and felt smooth as butter. I missed that, kinda forgot how good the stock shocks were. If only I could have it again.....
Old Jun 2, 2004 | 10:52 AM
BajaIowa's Avatar
With the preloads are spun all the way to the top the springs will rattle because that is how you disassemble them. Just loosen it up enough that with the suspension all the way down the preload nuts just hold the springs from rattling. You can get that kind of ride and still be able to jump big with a good set of aftermarket shocks. I regularly do 50-60 ft doubles at out local track and my quad still rides way better than my buddies new hondas and yfz's.
Justin
Old Jun 2, 2004 | 10:00 PM
Ya I know what ur saying, and I used to be able to achieve that kind of ride on the same shocks by playing with the preloads. All I'm saying now is the springs seem permantly more compressed than wheh they did before
New springs worth?
Old Jun 2, 2004 | 10:39 PM
BajaIowa's Avatar
Unless the springs are cheap, I would just spend the money on a good set of aftermarket shocks.
Justin
Old Jun 3, 2004 | 02:22 AM
And whats a good set of aftermarkets that ain't gonna drain me? I like the stockers, although I have never experienced a top end aftermarket. Which is the best bang for the buck? I mean good improvement and still cheap?
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
