warrior owners need help asap.....
Old Jun 2, 2004 | 11:43 PM
yamahawarriormods's Avatar
Default warrior owners need help asap.....
i just installed my new stage 1 hotcam there is a huge increase in power but there is a weird pinging noise or valve slap.... am i suposed to use the stock valve clearence i only rode it for like 5 min didn't want to hurt anything but i really need to no why its making that noise PLEASEhelpme so i can get out riding any sugg. would be great.....[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jun 2, 2004 | 11:49 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
what kind of noise xactly is it making?
Old Jun 3, 2004 | 12:18 AM
Boxhead's Avatar
My advice would be to follow the clearance the cam directions gave you. Did you make sure the feeler guage had a slight tension when you pulled it between the screw and sub rocker? It should only have a light resistance when pulled out. There will probably be a difference between the intake and exhaust clearance also, so be sure you didn't use the same for both by accident. If you just placed a higher compression piston in it could just be that the octane level isn't high enough. A 10.75 to 1 should use 93 (premium) and the race piston (12comp) should use race gas mixed with premium. Did you also do the break in period when starting it the first time? You should probably have had the engine always reving at a high idle for 15min before riding. Another problem I know about with the web race cam is the head must be modified for the larger lobes on the cam (metal must be grinded out, which hopefully isn't your case!!!). Be sure to check all the above, I just rebuilt a 400EX with a friend of mine and these were the guidelines to follow, except the bit about the warrior needing the head to be modified for the race cams. I'm not sure if this mod needs to be done to a hotcam stage 1.
Old Jun 3, 2004 | 09:44 AM
thanks for the help so far... and yeh i do have a wiesco piston but it never did this before also after i figure this problem will i need to rejet...... i cant explain the noise although it is in sink with the motor...
Old Jun 3, 2004 | 10:31 AM
SpinCycle's Avatar
Did you torque the head and clean the sealing surfaces? a leaking head gasket sounds like something trying to pound the head off the engine....
Old Jun 3, 2004 | 10:35 AM
NLWarrior01's Avatar
sounds like preignition ping to me. If you're running 87 octane bump up to the next level and see what happens. That is if it's a ping sound you're hearing.
Old Jun 3, 2004 | 08:45 PM
yeh i put all new head gaskets in and cleaned it off real good.... although today was messing with the valve clearence and it seemed to make alot of the noise go away.... but it still sounds a little different somebody told me that with i new high lift cam that it can some times take a few rides to make the valves ajust to the new cam but i dont no....
Old Jun 3, 2004 | 10:07 PM
yeh its still making the noise it sounds like the rocker arms and its more of a ticking noise just cant figur out why i have checked the valve clearence at least 5 times now
Old Jun 3, 2004 | 10:34 PM
SpinCycle's Avatar
Did you install new valve springs with the cam? the stock springs are really bad and will allow the valves to float with a big cam...
Old Jun 3, 2004 | 10:38 PM
no i did not but its doing this at idle and all through the revs [img]i/expressions/face-icon-small-confused.gif[/img]
