250r carb`
Old Aug 3, 2000 | 01:08 PM
400exalltheway's Avatar
what poilet jet should i put in it? it has a 310 kit done by ct racing and the carb is a 39 pwk kiehin with a lrd pipe. and tips on where to start for a mian jet and needle nouch would be apprieacated
Old Aug 3, 2000 | 01:50 PM
retro's Avatar
I would try a 160 main, needle in the middle position, and 55 pilot to start. First just get it to idle, then work your way up to full throttle with the main.
ERIC
Old Aug 3, 2000 | 06:23 PM
Witz's Avatar
A 160 would be much too lean on the main.
If you're using a 39 PWK with a 310, you should start with a 55 pilot, a 188 or 190 main and set the needle clip in the middle notch. The clip position also depends on the needle you have. I'm using a 38 PWK Air stryker on my 310 and am set with a 52 pilot, DGH needle w/clip in middle notch, and 188 main. The settings I recommended are a good starting point, but will not be exact. My other R, still at 250cc using a 39 PWK, is set with a 55 pilot and 178 main. Good luck
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Dustinyoungs
Jul 24, 2015 07:18 AM
Aitch
Jul 21, 2015 09:40 PM
CRamshaw777
Jul 18, 2015 05:46 PM
