350x + water
Old Jun 4, 2004 | 01:53 AM
sharpie's Avatar
Default 350x + water
well, my brother got washed down a creek, and before the 350x died it sucked about a quart of water in with the oil. it hasnt ran since. we have changed the oil, but it still wouldnt run, so we towed it behind the foreman and it sputtered alittle, but still no go. so we took it back into the shop and draind the oil again, and took the muffler off and drained it. now we are letting the oil drain totally over night and we are going to try again tommrow. we already drained some gas and it was fine. so is there any obvios reason why it isnot running? if it dosnt run tommrow we will be about out of ideas.
Old Jun 4, 2004 | 08:45 AM
RancherS01's Avatar
Is there any chance there is water in the carb? Maybe empty the carb bowl and see if that helps. Also, maybe there is some water in the cylinder, I'ld turn the bike over without the spark plug in to make sure.
Old Jun 4, 2004 | 10:58 AM
drummerguy84's Avatar
I'm surprised it didnt crack the piston or head, but you never know, water doesnt compress....im sure something got hurt pretty hard [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jun 4, 2004 | 05:49 PM
sharpie's Avatar
when he hit the creek the current turned him downstream and the water flowed in the muffler and i'm guessing that the backpressure killed the engine. we havnt tried it since we drained the exhaust, we are hoping that was it. it never fliped, nathan kindof rode it down, then we drug it up the bank with the foreman. we kicked it a few times right there and it turned over fine so there was no water in the cylinder. the airbox was dry too. the crank case did suck alot of water however, but i dont see any damage. we pulled the plug and didnt see anything out of the ordinary when we kicked it over. we changed the oil twice. we drained the carb too. we havnt taken it off to inspect it though, but we dont suspect anything out of the ordinary up there. so where is the major entry point for water? jsut the crankcase breather? also any non-water friendly electronics on it? it has spark so i didnt think so.
Old Jun 4, 2004 | 07:49 PM
sharpie's Avatar
well, he got it running today when i was at school. still not totaly sure what the problem was, probably water in everything. he says its back to normal. so how many oil changes untill the engine will be 100%water free? its on its second and i'm not sure that its all out. we'll probably run the cheap oil for alittle while and then change to honda oil again when we are sure.
Old Jun 4, 2004 | 08:11 PM
loveotride123456789's Avatar
some one told my to put alcohol or dry gas if u ever get water in your gas tank and do u think if u puered some in the cilander and let it evaporate the water would go a way
and that old tnt in your pics i know what y mean about some thing back firing inbetween your legs i need to put new gaskits in my and it should be ready to run this winter if we get any snow
Old Jun 4, 2004 | 08:23 PM
sharpie's Avatar
yeah, that tnt, man its fast for how old it is, but it dont steer woth a.... last time i had it out the exhaust pipe blew off the engine.. it will probably stay that way. i'm not sure if earplugs are going to cut it, its LOUD!! it actually runs amazingly well, if you can get it to start. the E clip on the pull rope came off and left me stranded. i think that you can still see the tow rope tied to the front bumper in the pic! i havnt touched it since i parked it. i might get that back together by winter. its one of those things that you run once a year because it takes about a year for you to forget last years accidents. the gas is fine on the 3wheeler, but we are still watching the oil, well atleast its running again.
Old Jun 4, 2004 | 09:05 PM
whitebroskfx440's Avatar
get a new sparkplug?
Old Jun 5, 2004 | 01:35 AM
sharpie's Avatar
no, is there any need? it probably needs to be replaced anyhow. the gaps on though.
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
