Scrambler problem
Old Jun 4, 2004 | 11:29 PM
trailrider500's Avatar
Default Scrambler problem
A friend of mine is having some trouble with his scrambler(my old scrambler 500). When he hits the throttle say from 1/4 to 1/2 it will act like the reverse rev limiter is kicking in but its in forward.He also said it will do it from a dead stop and from there he can only get it to go about 10mph but it dont do it all the time it does it every now and then...
Any ideas or things to check out?
I'm going to look at the scrambler tomorrow.
Thanks
Old Jun 4, 2004 | 11:56 PM
ftwflh's Avatar
TRy to bypass the reverse limiter.Not sure on the newer models but on the old ones you could unplug the black wire and bypass the box.Plus check the pilot jet it could be plugged up.Or it could be as simple as a dirty air filter.
Old Jun 5, 2004 | 12:24 AM
DGpolaris2346's Avatar
Same thing happened to my 2002 Trailblazer 250. All i did was unplug all the wires going into the reverse limiter and removed it. After i did that everything worked fine.
Old Jun 5, 2004 | 12:45 AM
too2tall's Avatar
how long is the vent hose on the bottom of the carb my scrambler was running with a stumble or popping at 1/4 and then gun it seen the barb for a hose on the bottom and put a hose on it upto the bars and it runs alot better?
Old Jun 5, 2004 | 01:23 AM
BigBadScrambler's Avatar
The reverse limiter just unplugs. But, to get the 4wd to work in reverse w/o pushing the button requires a little wire reworking
Old Jun 5, 2004 | 06:29 AM
crpadiem1's Avatar
like a couple of others here have said, disable the reverse limiter by pulling the black wire off the box, or at least that is the way it was on my trailblazer. I think mine was caused by pressure washing the area where the box was, stumped me for a week until I tried pulling the wire.
Old Jun 5, 2004 | 10:57 AM
Are you guys talking about just unplugging the button or? Where is the reverse limiter box located...
Thanks guys for the help...
Old Jun 5, 2004 | 01:57 PM
TR- Take off the hood. Under there, you will see a connector with 2 wires coming in and 2 coming out. One of them should be a gray wire with an orange stripe. Unplug that one. The reverse override is now disabled. To get the 4wd to work in reverse w/o pushing the button is a little more involved though.
Old Jun 5, 2004 | 05:37 PM
flon440's Avatar
It actually sounds a fouled spark plug.
it would probably be the easyer problem to check first.
Old Jun 5, 2004 | 07:44 PM
Well, we disconnected the reverse limiter still does it, checked just about everything but its still doing it. Its happening all the time now. He ordered a CDI today thinking thats the problem...
