84 TRX200, ignition problem - no spark
Old Jun 6, 2004 | 12:28 PM
Indianboy's Avatar
Default 84 TRX200, ignition problem - no spark
I get no spark at the plug on my 1984 TRX200. The coil checks OK - 9.28K ohms to ground, primary to ground .3ohms, green to ground OK. The pulse generator measures 32 ohms.
The CDI unit gets 12 volts to the gray, black yellow to the coil is OK, green to ground is OK, blue/yellow to the pulse generator is OK, black has no continuity with the ignition switch.
I have swapped the CDI unit with a known good one but no luck.
Got any ideas?
Also, what does the black/red wire to the ac generator do?
Where physically is the inhibitor switch and what is it's function?
Would appreciate any input.
Dave
Jmuddin284
Jan 19, 2026 07:16 AM
toonces
Oct 16, 2019 12:11 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
ranvette
Jul 4, 2015 06:13 PM
D-Hagz
Jul 4, 2015 02:19 AM
