Big Bear will only idle
Old Jun 6, 2004 | 08:42 PM
ztec's Avatar
Default Big Bear will only idle
Can anyone tell me what my problem sounds like? My 99 big bear 350 starts fine and idles fine, then as soon as I hit the gas it hesitates then stalls. The problem dident slowly start, it ran fine then I turned it off for a few minutes and the problem started. It seems like it would be a fuel related problem, theres no clogs or anything in the fuel line.
Old Jun 6, 2004 | 09:38 PM
hondabuster's Avatar
Could be a plugged pasage in the carb. Try using the choke and see if it gets better. If so, then you probably have an obstruction in the carb, and its running lean. Any chance youre out of gas, and need to use reserve?
if you give it gas slowly, does it stall then? How old is the gas?
Ean
Dec 19, 2022 08:48 AM
Cummins Driver
Sep 11, 2019 01:22 PM
house1
Aug 9, 2015 10:49 PM
clsharky
Jul 13, 2015 02:07 PM
ranvette
Jul 12, 2015 06:34 AM
