Raptor wont start
Old Jun 7, 2004 | 12:32 AM
fbiguy1's Avatar
Default Raptor wont start
Hey guys I have a 2001 Raptor 660 that won't start. When you press the starter button the starter just spins but nothing happens. It makes a nice zzzziiiiinnnngggg sound but. What the hell is causing this problem and how much will it break the bank to fix? Thanx for all the help guys.
Old Jun 7, 2004 | 01:02 AM
Turtler's Avatar
Well, sounds to me like the starter throw out bearing is not engaging. It will cost you $255 to get an L&A One Way replacement for the bearing, idler gear and gaskets to fix it, (and a gear puller if you dont have one). I got mine from Ripper Racing. Dont replace the throw out bearing with a stock piece of crap. Go to Raptortranny.com to get excellent directions for this fix. Good luck. Mine and a buddy of mine's throw out bearing failed in the same way.
Thanks again Yamaha for putting a **** design in the Raptor year after year.
Old Jun 7, 2004 | 01:03 AM
Rook's Avatar
Does the starter actually turn over? Does it sound like it might start, but then doesn't? I had this problem once before and it was because of the parking brake. I released it up at the handle bars, but it doesn't release all of the way. The cable on the back of your quad (above the swing arm) may be stretched, so it's not releasing all of the way. I don't quite understand why this affects wheather the quad starts or not, but it does. It would have costed me close to $300.00 to replace the parking brake, but I chose to block it off and do with out a parking brake. That only cost me about $20.00.
Old Jun 7, 2004 | 01:40 AM
fbiguy1's Avatar
The starter spins freely but there is nothing going on with the engine itself. I even cracked open the starter gear cover and checked. The starter is spinning all the visible gears
Old Jun 7, 2004 | 05:35 AM
BlackWidow's Avatar
Sounds like your starter one way to me. I bought one of the L&A Design setups and it has been flawless ever since. I got mine from Ripper Racing also and I think that they have the best price out there. As for instructions on replacement, use RaptorTranny.com. Awesome site and wonderful instructions!! There's also a lot of additional stuff there that is handy.
AtvManiac78
Jul 11, 2015 03:20 AM
VascoConroy
Jun 12, 2015 10:30 AM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
