warrior carburetor
Old Jun 7, 2004 | 10:16 AM
Vipers619's Avatar
Default warrior carburetor
will a 99 warrior or a newer carburetor fit onto an older 88 model warrior? will the accelerator pump have any conflict?the only thing i will need is a new throttle cable because i have the two cables so i will need the cable and the hook-up thing onto the carb,right?
Old Jun 7, 2004 | 11:43 AM
NLWarrior01's Avatar
From all I can tell Yamaha used that exact same carb on all model years of the Warrior and every other 350CC Warrior based engine .. bigbear, wolvy etc ...
So you should have no troubles with that. Hopefully if there are any troubles someone here will pick up on it. Those carbs are pretty simple ..
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
Ask the Editor
Sep 14, 2015 08:57 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
