700 sportman front axle yoke
Old Jun 7, 2004 | 04:02 PM
four4fish's Avatar
Default 700 sportman front axle yoke
does anyone know how to remove the axle yokes from front differental on an 02 . have new gorillas coming and want to get started thanks
Old Jun 7, 2004 | 07:01 PM
firemedic5586's Avatar
Its easy to do. I can swap out axles in my 700 in under 20 min and a couple of beers.
1) Pull your tire
2) Pull the black plastic cap off that gives you accses (SP) to the crown nut were it goes through the hub. Pull the crown nut.
3) Disconect your lower ball joint, drop your lower A-arm.
4) Rap on the end of your axle a few times with a 2x4 to brake it free as your pulling your front strut out and to the rear. You may have to loosen your brake lines, but your should be able to get the axle out of your hubs without taking your struts off. ( I can, but I also have a 3" lift in the front..YMMV)
5) Give the axle a "tug" it will pop out of the front diff. This "tug" may be a 10# sludge hammer with a metal cable wrapped around the head, and the other end of the cable wrapped between the u-joint and the front diff. Thats how I ended up getting my axles out the 1st time. When you put the gorillas in use anti-seeze compound on the splines. That way they come out real easy for when you trash a boot.
Old Jun 7, 2004 | 07:34 PM
four4fish's Avatar
thanks it looked t\like there was a snap ring inside the case as i looked at it in a parts manual.are the yokes male or female end that go to the diff thanks joe
Old Jun 8, 2004 | 03:43 AM
The splines that go into your diff are male. Yes there is a snap ring that goes on the end of your axle (diff side). That is what the "tug" dislodges when you remove the axle from the front diff. Where the Sludge hammer "tug" comes in is where the male splines are sort of rusted into the the female part of the front diff.
Old Jun 8, 2004 | 01:57 PM
four4fish's Avatar
thankyou firemedic im off to the depot for the cable
Old Jun 8, 2004 | 03:01 PM
Don't forget to auger out those front struts enuf so the new gorlia's will fit. Or you will be buying new boots, been there done that, have the tee shirt.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Jul 28, 2015 01:58 PM
carolinabomb
Jul 26, 2015 08:40 AM
Peter_
Jul 18, 2015 07:06 AM
Rider252
Jul 6, 2015 03:37 PM
