400EX clutch, shifting??
Old Aug 4, 2000 | 10:28 AM
Steven's Avatar
Lately my 400EX hasn't been shifting as smooth as it should. Sometime, when I ride hard it will stick in a gear and won't come out until I slow down the revs. I think it is probably my clutch, but I would like to hear what others have to say first. I've had this fourwheeler a year now, without ever changing or adjusting the clutch. So, what do you think. Clutch?
Old Aug 4, 2000 | 10:55 AM
LT250R_86's Avatar
When was the last time your changed the tranny oil and filter?
Old Aug 4, 2000 | 01:45 PM
Steven's Avatar
I just changed the oil and filter a little while ago. I used Mobil 1 15w/50. Should I use something different?
Old Aug 4, 2000 | 03:47 PM
Skunky's Avatar
Tranny oil??? Isn't the normal oil the tranny oil??? If not where is the drain plug?...
Old Aug 4, 2000 | 04:01 PM
86atc250r's Avatar
The oil is not the problem.
How does the bike react when idling in neutral, pulling in the clutch and shifting into gear? Does it lurch forward and lower the RPMs? If so, adjust your clutch...
Have you ever had the clutch really hot or run the bike low on oil?
You didn't put the filter in backwards did you (you would probably know by now )
And no, in most 4 stroke bikes the tranny oil and engine oil are one in the same.
Steeldon
Sep 9, 2015 09:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
cdstang
Aug 31, 2015 07:52 AM
