Sportsman 700 water pump cover
Old Jun 8, 2004 | 01:43 PM
SnowDrift's Avatar
Default Sportsman 700 water pump cover
I have an '02 model and have learned of bad water pump covers causing leaks. Mine has only about 60 hours on it and has an anti-freeze leak. I asked my local dealer about it and he's told me the recall is over. Is this true or should I get a second opinion from another dealer? Is this a service bulletin or a recall? Any reference numbers?
Thanks,
SnowDrift
Old Jun 8, 2004 | 01:48 PM
Polaridoo's Avatar
If you have a good dealer, they will take care of it for you. I don't know if there was ever an 'official' recall on the cover, but most good dealers will fix it or give you the parts for free. It is true that the water pump cover had a fix (metal cover that bolted over top of it), but they can also leak from the weep hole. When the mechanical (ceramic) seal goes bad it will leak from there. I think that seal was a weak point also - especially since they redesigned it. On my '02 700 I did the water pump cover and mechanical seal and it never leaked again. Clean up the cover as best you can and determine for sure where the leak is.
Old Jun 11, 2004 | 02:49 AM
jimmypsp700's Avatar
If you have the original plastic cover and it leaks they sold fix it even out of warry. mine did.
Old Jun 11, 2004 | 12:12 PM
profish00's Avatar
The cover is only 25 dollars and you can purchase it over the net
Text
http://partsland.com/index.cgi?N=108...700-WATER-PUMP
KimSJoh
14
Jul 18, 2015 07:20 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Coryco
Jul 6, 2015 07:30 PM
Mikea1978
Jul 4, 2015 12:37 PM
