o3 trailblazer
Old Jun 8, 2004 | 08:37 PM
gatorracing's Avatar
Default o3 trailblazer
Help! My daughter has an 03 Trailblazer with few hours on it. A few weeks ago, it started idling poorly and became hard to start to the point that she could barely get it to run. I did a compression check, which showed only 90 psi. I figured it just needed a new top end so I picked up a new +.020 Wiseco piston/rings/gaskets/etc had the cylinder bored put it all together and it still wont run. Compression is still only about 90 psi. Any one have any suggestions?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 8, 2004 | 08:42 PM
DGpolaris2346's Avatar
You could have the head shaved .20 to bump the compression up.
Old Jun 8, 2004 | 08:58 PM
Troyer23J's Avatar
That would bump up comression, but there must be something else wrong.
I wouldnt go shaving the head yet.
Old Jun 8, 2004 | 09:42 PM
DGScrambler400's Avatar
this is an obvious question, but did you check the air filter? It wont run worth $h!t if the air filter is clogged/dirty.
Old Jun 9, 2004 | 02:07 AM
Yes, I did check/clean the airfilter and put in a new plug. I've been told that it may be one of the main shaft seals where the crank penetrates the case, but that sounds a little 'iffy' to me. Possible?
Old Jun 9, 2004 | 07:55 AM
ftwflh's Avatar
Get a good compresion gauge and do a bleed down test to see if you have a leak in the motor(like the seals)
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
