1987 Honda 250x
Old Jun 8, 2004 | 11:56 PM
Eman1989's Avatar
Default 1987 Honda 250x
I've got a fortrax 250x and was wantin to do some cheap mods to it, does anyone have some suggestions?
Old Jun 9, 2004 | 01:33 AM
BRAD14's Avatar
pipe,jets will be the first thing you want to do to it.also by reading your sig it sounds like you could use some new plastics,just dont get black.then after the pipe and jets,a big bore or stroker kit will give you alot more power.
Old Jun 13, 2004 | 10:55 PM
Eman1989's Avatar
Ok,, I've found a set of complete set of pipes on denniskirk,, but they dont have a spark arestor, and dont make one for this system... Will that matter, and how much will it affect the sound?
The pipes are DG RCM Aluminum ATV Silencer W/O Spark Arrester
Does anyone know what this will sound like on this fourwheeler???
Old Jun 13, 2004 | 11:32 PM
TractorPacker's Avatar
Do you have a balloon?
Don't settle for a pipe you don't want. All 300ex pipes fit it, also. There is alot more choices that way.
Old Jun 14, 2004 | 12:08 AM
Eman1989's Avatar
Thanks for that advice,,, i will keep lookin now that my search has been widened a little bit.
Old Jun 14, 2004 | 09:50 AM
DeuceRooster's Avatar
Yea these other guys are right. Pipe and re-jet should be your first mod. I've had DG pipes before and they are not of the best quality however they get the job done. If you plan to keep the 250x though I'd go with a white brothers or FMF maybe even a Supertrapp.
Old Jun 14, 2004 | 01:01 PM
jstaguy24's Avatar
I put a complete big gun system on my 250x bought it from rocky mountain atv. opened up my airbox and jetted it. Made a nice difference
Old Jun 14, 2004 | 11:55 PM
The FMF is a good pipe but will melt your fender. I have good about the big gun and tried the E-series on a 305ex big bore and it helped that engine out. The E-series on the 400ex are junk and fall apart so take that in to consideration.
Old Jun 15, 2004 | 01:19 PM
95wolv's Avatar
Most aftermarket pipes will run real close to the rear fender by the seat and melt holes if you're not careful.An easy fix is to mount the pipe, mark on the fender where the pipe comes close,and put some adhesive - backed heat tile/fabric on those areas. I did that with my son's 300ex, and have been running a Supertrapp pipe for almost a year now with no burns or melted spots.
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
rgjackson
Sep 17, 2015 11:21 AM
stcspiderman
Sep 13, 2015 05:15 PM
Steeldon
Sep 8, 2015 10:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
